JohnJohn20
- Joined
- Feb 2, 2012
- Messages
- 111
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,296
- Activity points
- 2,377
OK. A low-pass filter is a filter that passes low-frequency signals and attenuates (reduces the amplitude of) signals with frequencies higher than the cutoff frequency.
I understand the words but, how does a low pass filter affect an increase in the input voltage?
For example, what will happen to the output of a unity gain op amp low pass filter if the input voltage increases from 2V to 4 V over 0.5 seconds?
Do we treat this as an AC signal with a period of 2 seconds or 1 second or what?
What is the minimum cutoff frequency of this op amp filter that will allow this change in input voltage but stop any higher frequency noise?
FYI. I am trying to monitor a high impedance (~5MΩ) voltage for changes in voltage that take between 0.25 and 0.5 seconds to happen.
I have a sensitive detector but I am having a lot of problems with noise getting into the detector input. Any suggestions would be appreciated.
Would a two pole low pass unity gain op-amp filter circuit be the right way to approach this problem?
Thanks for reading.
Thanks for reading.
