DNP3/PSTN interface with microcontroller
girish_wabale
Member level 3
Pune
pstn+microcontroller
Hello ,
I have to take data into microcontroller from DNP3 and PSTN interface.
the uC having 4 UART lines RX,TX, CTS and RTS.
But I am new to these interfaces . Can anybody help me by posting some literature
schematic, application notes regarding the same.
In my application
I have to take data from DNP3 /PSTN interface into uC and sending it to another DNP3 /PSTN interface after processing
Thanks and Regards
Girish Wabale
If by PSTN you mean the telephone network, you need a modem to transfer data between the netwrok and the microcontroller.
most of the modems work on AT command set, you can google and find the AT command set.
and you can design your own protocol if you need. you can transfer data between two micros using DTMF (dual tone multi frequency) and the telephone network.
Thanks Vinod KP
In my application I have to replace the PSTN Modem by my device which wil send the data wirelessly to another Device which will send the data into PC.
I am confused about interface . Can anybody explain me in detail
Regards
Girish
Hi
The comm method you describing is look like hardware handsheak using the RTS - request To Send & Clear To Send signal
Search google for hoe to use RTS & CTS signals also search for X modem and Z modem protocol
All the best
Bobi
