DIY Test Pattern Generator
rhmbl
Newbie level 1
Im looking to build a small, preferably portable, Test Pattern Generator for monitors etc. Can anyone assist me? I would like to be able to display, on the output, either 75% or 100% test bar pattern. With the output being SDI/VGA/HDMI.
Any assistance would be greatly appreciated.
Thanks
first set up your specifications.
Draw diagrams for hardware, first raw, then refine it step by step.
Describe your ideas. Connectors, video standards, you want to implement. Power supply.
Video resolutions...and how to handle DDC?
There´s a lot you have to consider before you can start hardware design.
Klaus
What we did, in a factory I used to work, is to employ a laptop. It already had the prerequisite VGA and HDMI outputs, you could change the resolution (within certain range) and the available test patterns were only limited by the ability to draw them or download it from the internet.
If a laptop is too large, perhaps a Raspberry Pi would be a solution. I've never personally worked with a Rasperry Pi, but understand that a project like yours is perfectly doable.
It only has a HDMI and composite video outputs, but building/purchasing an HDMI to VGA converter should be far easier.
