DIY Moving Message Display
OBIALOR Thanks for you help I will go through it and if I have any question i will ask.
If you're having trouble with multiple 8x8 LED blocks, try this with a single 8x8 just for fun:
sn_burki said:
There is no project but a video?
It's a demonstration only. A good programming challenge for someone willing to try it.
Programming with PIC BASIC
Anyone know where can i search for more information about "how to program a PIC 16F877 with PIC BASIC?
hi
I am crazilly looking for help to build moving message display controlled by sms by 3310. can any one please help?????????/ how can i understand AT commands? can i use it for NOKIA 3310????????/
hi sn_burki, i think there are lots of sources over the internet regarding in understanding the AT commands. try searching! : )
hi to all
this is the program for moving meesage display that i download it from this topic .
i want to show my own message :( I AM LIREZA MOHAMMADI ) in the output.
what change i shoud do in this program?
MATRIX FORMAT
ROW & COL ACTIVE HI
COL SCAN BY 74LS164
-----------5
-----------4
-----------3
-----------2
-----------1
-------2 1 0
#include <reg51.h>
#include <intrins.h>
#define TRUE 1 /* define logical true / false */
#define FALSE 0 /* values for bit variables */
#define SCROLL_DELAY 60 /* scroll delay */
#define TIMER0_COUNT 0xFADA // 1.1ms
void delay_us(unsigned int d);
typedef unsigned char byte; /* type define objects with */
typedef unsigned int word; /* more classical microprocessor */
code char menu[] =
"\r\n\n\n\n\n\n\n\n\n\n\n\n\n"
"Walking led message display program\n\r"
"___________________________________\n\r"
"Written by Sohail Shahzad\n\n\n\n\r"
"Press:-\n\r"
" s to load the message from the PC terminated in a $/r/n"
" d to display message/r/n/n/n/n";
code unsigned char matrix[59][6]=
{0x00,0x00,0x00,0x00,0x00,0x00, //space
0x00,0x00,0x7d,0x00,0x00,0x00, //!
0x00,0x60,0x00,0x60,0x00,0x00, //"
0x14,0x7f,0x14,0x7f,0x14,0x00, //#
0x32,0x49,0x7f,0x49,0x26,0x00, //$
0x62,0x64,0x08,0x13,0x23,0x00, //%
0x36,0x49,0x35,0x02,0x05,0x00, //&
0x00,0x00,0x00,0x50,0x60,0x00, //'
0x1c,0x22,0x41,0x00,0x00,0x00, //(
0x00,0x00,0x41,0x22,0x1c,0x00, //)
0x2a,0x1c,0x3e,0x1c,0x2a,0x00, //*
0x08,0x08,0x3e,0x08,0x08,0x00, //+
0x00,0x01,0x02,0x00,0x00,0x00, //,
0x08,0x08,0x08,0x08,0x08,0x00, //-
0x00,0x00,0x01,0x00,0x00,0x00, //.
0x02,0x04,0x08,0x10,0x20,0x00, ///
0x3e,0x45,0x49,0x51,0x3e,0x00, //0
0x00,0x21,0x7f,0x01,0x00,0x00, //1
0x27,0x49,0x49,0x49,0x31,0x00, //2
0x22,0x49,0x49,0x49,0x36,0x00, //3
0x0c,0x14,0x24,0x7f,0x04,0x00, //4
0x7a,0x49,0x49,0x49,0x46,0x00, //5
0x3e,0x49,0x49,0x49,0x26,0x00, //6
0x41,0x42,0x44,0x48,0x70,0x00, //7
0x36,0x49,0x49,0x49,0x36,0x00, //8
0x32,0x49,0x49,0x49,0x3e,0x00, //9
0x00,0x00,0x22,0x00,0x00,0x00, //:
0x00,0x01,0x22,0x00,0x00,0x00, //;
0x08,0x14,0x22,0x41,0x00,0x00, //<
0x14,0x14,0x14,0x14,0x14,0x00, //=
0x00,0x41,0x22,0x14,0x08,0x00, //>
0x20,0x40,0x45,0x48,0x30,0x00, //?
0x3e,0x41,0x4d,0x4d,0x39,0x00, //@
0x1f,0x24,0x44,0x24,0x1f,0x00, //A
0x7f,0x49,0x49,0x49,0x36,0x00, //B
0x3e,0x41,0x41,0x41,0x22,0x00, //C
0x7f,0x41,0x41,0x22,0x1c,0x00, //D
0x7f,0x49,0x49,0x49,0x41,0x00, //E
0x7f,0x48,0x48,0x48,0x40,0x00, //F
0x3e,0x41,0x41,0x45,0x26,0x00, //G
0x7f,0x08,0x08,0x08,0x7f,0x00, //H
0x00,0x41,0x7f,0x41,0x00,0x00, //I
0x42,0x41,0x41,0x7e,0x40,0x00, //J
0x7f,0x08,0x14,0x22,0x41,0x00, //K
0x7f,0x01,0x01,0x01,0x01,0x00, //L
0x7f,0x20,0x18,0x20,0x7f,0x00, //M
0x7f,0x10,0x08,0x04,0x7f,0x00, //N
0x3e,0x41,0x41,0x41,0x3e,0x00, //O
0x7f,0x48,0x48,0x48,0x30,0x00, //P
0x3c,0x42,0x46,0x42,0x3d,0x00, //Q
0x7f,0x48,0x4c,0x4a,0x31,0x00, //R
0x32,0x49,0x49,0x49,0x26,0x00, //S
0x40,0x40,0x7f,0x40,0x40,0x00, //T
0x7e,0x01,0x01,0x01,0x7e,0x00, //U
0x78,0x06,0x01,0x06,0x78,0x00, //V
0x7f,0x02,0x0c,0x02,0x7f,0x00, //W
0x63,0x14,0x08,0x14,0x63,0x00, //X
0x60,0x10,0x0f,0x10,0x60,0x00, //Y
0x43,0x45,0x49,0x51,0x61,0x00};//Z
code char TEST_MSG[]="WELLCOME TO ALIREZ MESSAGE $";
sbit LED_CLOCK = P3^2;
sbit LED_DATA = P3^3;
sbit LED_RESET = P3^4;
bit timer0_tick;
use the free-running I timer to multiplex the led displays
void multiplex() interrupt 1 using 1
TR0=0;
TL0=(TIMER0_COUNT & 0x00FF);
TH0=(TIMER0_COUNT >>8);
TR0=1;
timer0_tick=1;
void main(void)
int i,j;
unsigned char row;
unsigned char *dataPtr, *tmpDataPtr;
unsigned char messageLength, currentChar, charOffset, tmpCurrentChar, tmpCharOffset;
char msg[32]; // ram for message max length
unsigned char ledArray[32];
P1=0xFF;
P3=0xFF;
P2=0xFF;
EA =0;
TL0 = (TIMER0_COUNT & 0x00FF);/* timer 0 period 5ms */
TH0 = (TIMER0_COUNT >>8);
TL1=0XFD; //9600 @ 11.0592
TH1=0XFD;
//TMOD &=0xF0;
TMOD =0x21;
SCON =0X50;
ET0=1;
TR1=1;
TR0 = 1; /* enable timer 0 */
EA = 1;
RI=0;
main execution loop, executes forever.
LED_RESET = 0;
LED_CLOCK = 0;
LED_RESET = 1;
P1=0;
while(1){
for(i=0;i<sizeof(TEST_MSG);i++) msg=TEST_MSG;
for(i=0;i<48;i++) if(msg=='$') break; //calculate length of msg
messageLength = i;
charOffset = 0;
currentChar = 0;
dataPtr = &matrix[msg[0] - 0x20][0];
// this loop is the heart of the scroll
// message is scrolled until a key is hit on the keyboard
while (1) {
// load led array
tmpDataPtr = dataPtr;
tmpCharOffset = charOffset;
tmpCurrentChar = currentChar;
for (i = 0; i <= 31; i++) {
ledArray = *tmpDataPtr++;
if (++tmpCharOffset==0x06) {
tmpCharOffset = 0;
if (++tmpCurrentChar == messageLength)
tmpCurrentChar = 0;
tmpDataPtr = &matrix[msg[tmpCurrentChar] - 0x20][0];
if (++charOffset == 0x06) {
charOffset = 0;
if (++currentChar == messageLength)
currentChar = 0;
dataPtr = &matrix[msg[currentChar] - 0x20][charOffset];
// display led array
row = 1;
for (j = 0;j <= SCROLL_DELAY; j++) {
LED_DATA = (ledArray & row) ? 1 : 0; //invert image by interchng 0:1
LED_CLOCK = 1;
LED_CLOCK = 0;
P1 = row;
row <<= 1; // next line to be switched on
if (row==0x80) row = 0x01; // if last line go back to the first line
delay_us(1100);
P1 = 0x00;
}//while
}//while
}//----------------end main
void delay_us(unsigned int d){
unsigned int i,m;
m=d/14;
for(i=0;i<m;i++);
PostPosted: 18 Nov 2007 21:09 Post subject: Re: DIY Moving Message Display
hi
You cannot use AT commands on Nokia 3310, it uses FBUS protocol
if you want AT commands use 6210 or 6310 instead, these models work on either
FBUS (DAU-9P cable) or AT Commands (DLR-3P cable).
can you guys tell me that what is more easy to use fbus or to use ATcommands??? my second question is tha I read that NOKIA 3310 uses Fbus and Mbus then how to select any one of them?
hi to all!
i am a fifth year comp engneering student and i need a schematic diagram and a program of a programable running message. iam using a 5x7 dot matrix. and i really need a help.cos i am using a keypad controller to change the content of the running message.:cry:
Hi ,
can any body propose me a circuit diagram for a DMX led matrix 16x16 or 8x8 pixel with dip switch address for the unit.
Thanking you all in advance
hi everyone!is it possible to do 20 characters with shift registers controlled by one controller
Hi
I want LED DotMatrix Display that is controlled by PIC16F877A. I want to control it by Keyboard. So, please if you have any idea about this, help me.
