DIY Moving Message Display
8051 based moving message display
Thanks tobb
It is great... and thanks also for a part of software... Will you please let me have the hardware of your design... I want to study it also.
scrolling message display project
hi friend
you have to look at the mcs web page to get the code and idea how to design your own instead to reqeusting some one to write down code for you such deficult task
https://www.mcselec.com/an_128.htm
Reactions: PaulCo1
    Sadaf
    V
    PaulCo1
pic16f682
Dear Fragrance
Thanks for advice...
I have visited the site ... it is a good for me..
If some one have already done this task he may help me... I can use his software for studying mime... is not it good?
Waiting for your comments.
case study about moving message display
Look in the newest issue of the Elektor Electronics magazine (November 2003):
http://www.elektor-electronics.co.uk/ln/details/e1103u.htm
There's an article about a Running Text Display using an 89S8252 Flash MCU.
PCB layout and source & hex code can be downloaded here:
moving message software download
Is there a circuit based on the PIC controller also?
bimbla.
project led moving message display , download
hi friends
I need to build an floor indicator with two 5x7 moving number
but with pic 16f84
diy led moving message display
tekton said:
hi friends
but with pic 16f84
Why use the PIC16F84?
It's obsolete and way too expensive.
If you want to use PIC you should chosse the 16F627(A), 16F628(A) or 16F648A.
They are pin compatible replacements for 16F84(A), but much cheaper and with more features. 16F628(A) has 2 times as much flash and PIC16F648A has 4 times as much flash, but is still much cheaper than 16F84(A).
Please read this topic:
Prices for 18 pin PDIP, 1-25 units at **broken link removed**:
PIC16F84A-04/P (4 MHz): $5.05 (1024 words FLASH)
PIC16F84A-20I/P (20 Mhz): $5.94
PIC16F84A-20E/P (20 MHz): $6.50
PIC16F84A-20/P (20 MHz): $5.39
PIC16LF627A-I/P (20 MHz): $2.25 (1024 words FLASH)
PIC16F627A-E/P (20 MHz): $2.31
PIC16LF628A-I/P (20 MHz): $2.56 (2048 words FLASH)
PIC16F628A-E/P (20 MHz): $2.60
PIC16LF648A-I/P (20 MHz): $2.93 (4096 words FLASH)
PIC16F648A-I/P (20 MHz): $2.76
PIC16F648A-E/P (20 MHz): $2.97
If you want to use AVR instead, you could use AT90S2313, or the new cheaper, better and faster ATtiny2313, but ATtiny2313 is only availible as samples yet.
void main() portb=0b 74hc164 led matrix
hi
Here is the complete guide to building your own moving message display
using micro controller
This is a 89C2051 micro-controller project based and 7x16 LED matrix.
atmega 32 based moving message display
hello
just wondering if u dudes would be interested,
i built my own moving message display with following characteristics:
7x5 led matrix (only four characters at the moment, can be easily extended to any number of characters) connected to an at90s8535
in system programmable controller (very simple programmer), can display around 300 character long messages (depends on the available RAM in the chip) , the controller is connected to a PC keyboard directly,
so the message is typed in and displayed on an LCD (2x16 chars at the moment- also easily upgradable), with next version of software there will be an option for saving message in the
onboard EEPROM (512 bytes), the code is written all in C , compiled with CodeVision C compiler, I only used
their delay() library function so the code is easily portable to other
compilers.compiled code takes around 800 bytes + few hundred bytes
for the font and keyboard scancodes,
(the chip has got 4 K rom & 512 bytes of RAM), currently im working on
getting it to work under a small non-preemptive real time operating system. (also written in C).
here are few pictures of it, let me know if youre interested, thanks :))
moving message display panel
Questions:
1. How many 5x7 can it support?
2. Can the scroll be controleld?
a. Can it be paused.
b. Can it Scroll from top to bottom or vice versa?
3. Can the FONT be controlled?
Thanks.
led moving message display software
glenjoy said:
Questions:
Thanks.
hello :))
answers:
1. at the moment ,as I said before, the prototype works with 4 characters
i.e. there are currently 23 columns on the prototype,
it can be very easily extended to any number of columns/5x7s,
the only thing that would have to be changed then is the number of columns in the software e.g. via #define directive in C , or maybe I could add a
menu option for changing numbers of columns dynamically via PC keyboard , like
some sort of a configuration mode , theres plenty of room for experimenting :)))
2. at the moment, scrolling is happening from right to the left only, its a first version, the speed of the
scroll is controlled via #defines (software needs to be recompiled each time i change the speed ) but I can easily add few software functions so
its controlled via PC keyboard and speed /delay can be stored dynamically in the onboard EEPROM
a. not at the moment, but can be done (just need to change few lines of code).
b. see answer 2 :)) also easily done
3. font definitions are stored together with the code in an array in the
FLASH ROM, i guess i can add few new fonts , ive got around 2 KB left in
the ROM for that, font takes up about 600 bytes, so again , easily done.
(it would take even less without special characters, at the moment all
the charachters on a PC keyboard are supported)
this is the first rough version, If u dudes are interested I can post schematics and the code and then we can work on it from there, it is
pretty good as it is but as i said theres lots of room for experimeting and
improvements.
scrolling message display on 5by7 matrix of led
**broken link removed** has also a scrolling LED Display, I removed some codes in the software so that will not be confusing in using the software with stand alone micros.
I used DS89C420 with it and worked fine. But scrolling is from right to left only and can't pause/stop the display at the center.
Can someone give an idea how to pause it or scroll from top to bottom or vice versa?
Here are the softwares anyway if you don't want to visit the site.
16x16 led moving message projects
its in assembly with german comments :))
no wonder you want somebody else to figure it out for you :))
here is my code, all i do to scroll a message is load an array
with character definitions (5 columns for each char. + 1 emtpy column
for space between chars.) and then i move the dataPtr pointer along the
array, to pause the message i would just have to keep the pointer
the same i.e. not change it, i guess this german dude is doing something
similar, scrolling from bottom to top or vice versa could be done the
same way, but before loading the array with character definitions you
would have to shift the whole array (individual bytes) up or down .
also my display part is exactly the same as the display in the first
post, i.e. i used the same Silicon chip article to build mine, it was
connected to PC parallel port originally then I removed the parallel
port connector and connected it directly to microcontroller (PIC and then
at90s8535 :)), so the RC components that were used to clean up
noise coming out of parallel port could probably be removed, havent
tried it, anyway its just 10 resistors and capacitors , not very important
i guess.
and the keyboard interrupt service routine was written with the help
from Atmel dudes, it was in one of their application notes,
i cant remember the excact number of the note, i changed the code
a little bit, i.e. removed few lines of code from their source, if u want
to see the application notes it can be easily found on the Atmel web site.
my code: stuff im talkin about is in the main() function in the while(1) loop
#include <90s8535.h>
#include <delay.h>
// led display
#define LED_RESET		PORTB.0
#define LED_CLOCK		PORTB.1
#define LED_DATA		PORTB.4
#define SCROLL_DELAY	140  // multiple of 7 (use smaller numbers for faster scroll)
// keyboard
#define KBD_CLOCK		PORTD.2  // to be used for host -> keyboard communication
#define KBD_DATA        	PIND.4
#define BUFF_SIZE		64
// lcd
#define LCD_RS			PORTD.5
#define LCD_RW 		PORTD.6
#define LCD_E  		PORTD.7
#define COMMAND_MODE 	0
#define DATA_MODE    	1
#define WRITE_MODE   	0
#define READ_MODE    	1
#define LCD_DATA_PORT	PORTC
// functions
void lcd_init(void);
void lcd_clear(void);
void lcd_putc(unsigned char);
void lcd_putsf(unsigned char flash *);
void lcd_puts(unsigned char *str);
interrupt [EXT_INT0] keyboard_isr(void);
void put_char_kbbuff(unsigned char);
void put_scancode_kbbuff(unsigned char);
int getchar(void);
int kbhit(void);
void decode(unsigned char);
// global variables ***************************
unsigned char kb_buffer[BUFF_SIZE];
unsigned char bitcount;
unsigned char *inpt, *outpt;
unsigned char buffcnt = 0;
// led character definitions
// 5 data columns + 1 space
// for each character
flash unsigned char led_chars[94][6] = {
0x00,0x00,0x00,0x00,0x00,0x00,	// space
0x00,0x00,0xfa,0x00,0x00,0x00,	// !
0x00,0xe0,0x00,0xe0,0x00,0x00,	// "
0x28,0xfe,0x28,0xfe,0x28,0x00,	// #
0x24,0x54,0xfe,0x54,0x48,0x00,  // $
0xc4,0xc8,0x10,0x26,0x46,0x00,  // %
0x6c,0x92,0xaa,0x44,0x0a,0x00,  // &
0x00,0xa0,0xc0,0x00,0x00,0x00,  // '
0x00,0x38,0x44,0x82,0x00,0x00,	// (
0x00,0x82,0x44,0x38,0x00,0x00,  // )
0x28,0x10,0x7c,0x10,0x28,0x00,  // *
0x10,0x10,0x7c,0x10,0x10,0x00,  // +
0x00,0x0a,0x0c,0x00,0x00,0x00,  // ,
0x10,0x10,0x10,0x10,0x10,0x00,  // -
0x00,0x06,0x06,0x00,0x00,0x00,  // .
0x04,0x08,0x10,0x20,0x40,0x00,  // /
0x7c,0x8a,0x92,0xa2,0x7c,0x00,  // 0
0x00,0x42,0xfe,0x02,0x00,0x00,  // 1
0x42,0x86,0x8a,0x92,0x62,0x00,  // 2
0x84,0x82,0xa2,0xd2,0x8c,0x00,	// 3
0x18,0x28,0x48,0xfe,0x08,0x00,	// 4
0xe5,0xa2,0xa2,0xa2,0x9c,0x00,	// 5
0x3c,0x52,0x92,0x92,0x0c,0x00,	// 6
0x80,0x8e,0x90,0xa0,0xc0,0x00,	// 7
0x6c,0x92,0x92,0x92,0x6c,0x00,	// 8
0x60,0x92,0x92,0x94,0x78,0x00,	// 9
0x00,0x6c,0x6c,0x00,0x00,0x00,	// :
0x00,0x6a,0x6c,0x00,0x00,0x00,	// ;
0x10,0x28,0x44,0x82,0x00,0x00,	// <
0x28,0x28,0x28,0x28,0x28,0x00,	// =
0x00,0x82,0x44,0x28,0x10,0x00,	// >
0x40,0x80,0x8a,0x90,0x60,0x00,	// ?
0x4c,0x92,0x9e,0x82,0x7c,0x00,	// @
0x7e,0x88,0x88,0x88,0x7e,0x00,	// A
0xfe,0x92,0x92,0x92,0x6c,0x00,	// B
0x7c,0x82,0x82,0x82,0x44,0x00,	// C
0xfe,0x82,0x82,0x44,0x38,0x00,	// D
0xfe,0x92,0x92,0x92,0x82,0x00,	// E
0xfe,0x90,0x90,0x90,0x80,0x00,	// F
0x7c,0x82,0x92,0x92,0x5e,0x00,	// G
0xfe,0x10,0x10,0x10,0xfe,0x00,	// H
0x00,0x82,0xfe,0x82,0x00,0x00,	// I
0x04,0x02,0x82,0xfc,0x80,0x00,	// J
0xfe,0x10,0x28,0x44,0x82,0x00,	// K
0xfe,0x02,0x02,0x02,0x02,0x00,	// L
0xfe,0x40,0x30,0x40,0xfe,0x00,	// M
0xfe,0x20,0x10,0x08,0xfe,0x00,	// N
0x7c,0x82,0x82,0x82,0x7c,0x00,	// O
0xfe,0x90,0x90,0x90,0x60,0x00,	// P
0x7c,0x82,0x8a,0x84,0x7a,0x00,	// Q
0xfe,0x90,0x98,0x94,0x62,0x00,	// R
0x62,0x92,0x92,0x92,0x8c,0x00,	// S
0x80,0x80,0xfe,0x80,0x80,0x00,	// T
0xfc,0x02,0x02,0x02,0xfc,0x00,	// U
0xf8,0x04,0x02,0x04,0xf8,0x00,	// V
0xfc,0x02,0x1c,0x02,0xfc,0x00,	// W
0xc6,0x28,0x10,0x28,0xc6,0x00,	// X
0xe0,0x10,0x0e,0x10,0xe0,0x00,	// Y
0x86,0x8b,0x92,0xa2,0xc2,0x00,	// Z
0x00,0xfe,0x82,0x82,0x00,0x00,	// [
0x00,0x00,0x00,0x00,0x00,0x00,     // *** do not remove this empty char ***
0x00,0x82,0x82,0xfe,0x00,0x00,	// ]
0x20,0x40,0x80,0x40,0x20,0x00,	// ^
0x02,0x02,0x02,0x02,0x02,0x00,	// _
0x00,0x80,0x40,0x20,0x00,0x00,	// `
0x04,0x2a,0x2a,0x2a,0x1e,0x00,	// a
0xfe,0x12,0x22,0x22,0x1c,0x00,	// b
0x1c,0x22,0x22,0x22,0x04,0x00,	// c
0x1c,0x22,0x22,0x12,0xfe,0x00,	// d
0x1c,0x2a,0x2a,0x2a,0x18,0x00,	// e
0x10,0x7e,0x90,0x80,0x40,0x00,	// f
0x30,0x4a,0x4a,0x4a,0x7c,0x00,	// g
0xfe,0x10,0x20,0x20,0x1e,0x00,	// h
0x00,0x22,0xbe,0x02,0x00,0x00,	// i
0x04,0x02,0x22,0xbc,0x00,0x00,	// j
0xfe,0x08,0x14,0x22,0x00,0x00,	// k
0x00,0x82,0xfe,0x02,0x00,0x00,	// l
0x3e,0x20,0x18,0x20,0x1e,0x00,	// m
0x3e,0x10,0x20,0x20,0x1e,0x00,	// n
0x1c,0x22,0x22,0x22,0x1c,0x00,	// o
0x3e,0x28,0x28,0x28,0x10,0x00,	// p
0x10,0x28,0x28,0x18,0x3e,0x00,	// q
0x3e,0x10,0x20,0x20,0x10,0x00,	// r
0x12,0x2a,0x2a,0x2a,0x04,0x00,	// s
0x20,0xfc,0x22,0x02,0x04,0x00,	// t
0x3c,0x02,0x02,0x04,0x3e,0x00,	// u
0x38,0x04,0x02,0x04,0x38,0x00,	// v
0x3c,0x02,0x0c,0x02,0x3c,0x00,	// w
0x22,0x14,0x08,0x14,0x22,0x00,	// x
0x30,0x0a,0x0a,0x0a,0x3c,0x00,	// y
0x22,0x26,0x2a,0x32,0x22,0x00, 	// z
0x00,0x10,0x6c,0x82,0x00,0x00,	// {
0x00,0x00,0xfe,0x00,0x00,0x00,	// |
0x00,0x82,0x6c,0x10,0x00,0x00 };	// }
// keyboard scan codes (without & with shift key pressed)
flash unsigned char unshifted[67][2] = {
//0x0d,9,
0x0e,'`',0x15,'q',0x16,'1',0x1a,'z',0x1b,'s',0x1c,'a',0x1d,'w',0x1e,'2',0x21,'c',0x22,'x',0x23,'d',0x24,'e',
0x25,'4',0x26,'3',0x29,' ',0x2a,'v',0x2b,'f',0x2c,'t',0x2d,'r',0x2e,'5',0x31,'n',0x32,'b',0x33,'h',0x34,'g',
0x35,'y',0x36,'6',0x39,',',0x3a,'m',0x3b,'j',0x3c,'u',0x3d,'7',0x3e,'8',0x41,',',0x42,'k',0x43,'i',0x44,'o',
0x45,'0',0x46,'9',0x49,'.',0x4a,'/',0x4b,'l',0x4c,';',0x4d,'p',0x4e,'-',0x52,'`',0x54,'[',0x55,'=',0x5a,13,
0x5b,']',0x5d,'/',0x61,'<',0x66,8,  0x69,'1',0x6b,'4',0x6c,'7',0x70,'0',0x71,',',0x72,'2',0x73,'5',0x74,'6',
0x75,'8',0x79,'+',0x7a,'3',0x7b,'-',0x7c,'*',0x7d,'9',0,0 };
flash unsigned char shifted[67][2] = {
//0x0d,9,
0x0e,'`',0x15,'Q',0x16,'!',0x1a,'Z',0x1b,'S',0x1c,'A',0x1d,'W',0x1e,'@',0x21,'C',0x22,'X',0x23,'D',0x24,'E',
0x25,'$',0x26,'#',0x29,' ',0x2a,'V',0x2b,'F',0x2c,'T',0x2d,'R',0x2e,'%',0x31,'N',0x32,'B',0x33,'H',0x34,'G',
0x35,'Y',0x36,'^',0x39,'L',0x3a,'M',0x3b,'J',0x3c,'U',0x3d,'&',0x3e,'*',0x41,'<',0x42,'K',0x43,'I',0x44,'O',
0x45,')',0x46,'(',0x49,'>',0x4a,'?',0x4b,'L',0x4c,':',0x4d,'P',0x4e,'_',0x52,'"',0x54,'{',0x55,'+',0x5a,13,
0x5b,'}',0x5d,'|',0x61,'>',0x66,8,  0x69,'1',0x6b,'4',0x6c,'7',0x70,'0',0x71,',',0x72,'2',0x73,'5',0x74,'6',
void main() {
	int i,j;
    	unsigned char ch,row;
	flash unsigned char *dataPtr, *tmpDataPtr;
	unsigned char messageLength, currentChar, charOffset, tmpCurrentChar, tmpCharOffset, ledArray[23];
	unsigned char message[308];  // 300 chars + 4 spaces at start and end of message
	#asm("cli");    // disable all interrupts
	// initialise ports
	DDRA = 0xff;	// port A output
	DDRB = 0xff;	// port B output
	DDRC = 0xff;	// port C output
	DDRD = 0xeb;	// pins 2 & 4 inputs
	// initialise keyboard variables
	inpt = kb_buffer;
	outpt = kb_buffer;
	buffcnt = 0;
	bitcount = 11;
	// initialise lcd
	lcd_init();
	// initialise LED display (shift registers)
	LED_RESET = 0;
   	LED_CLOCK = 0;
 	LED_RESET = 1;
	// initialise interrupt registers
	GIMSK = 0x40;	// enable INT0 interrupt
	MCUCR = 0x02;	// INT0 interrupt on falling edge
   	#asm("sei");    // enable all interrupts
   	while(1) {
   		ch = 0x00;
    		i = 0;
    		// fill the array with 4 empty spaces at the start and the end of the message
		// as the screen has 4 chars
		// (it looks better if we start scrolling with empty screen and end
		// with empty screen , rather than displaying four chars immediatelly and
		// then start scrolling)
		message[i++] = ' ';
   		message[i++] = ' ';
   		message[i++] = ' ';
   		message[i++] = ' ';
		// enter message until 300 characters entered or <enter> key pressed
    		while((ch != 13) || (i < 308)) {
			ch = getchar();
			if ((ch != 13) && (ch != 'q')) {
				lcd_putc(ch);
				message[i++] = ch;
			// if q is pressed clear the LCD
			// (code only writes to the first LCD line so
			// if the line is longer than 16 chars i cant see the rest of the chars
			// , there will be a menu system in the future software version
			// and the line on the LCD will be scrolled
			// to the left automatically as the cursor gets to the end of the line
			//, for now use this dirty solution:))
			if (ch == 'q')
				lcd_clear();
    		message[i++] = ' ';
   		message[i++] = ' ';
   		message[i++] = ' ';
   		message[i++] = ' ';
    		messageLength = i - 4;
    		charOffset = 0;
    		currentChar = 0;
    		dataPtr = &led_chars[message[0] - 0x20][0];
		// this loop is the heart of the scroll
		// message is scrolled until a key is hit on the keyboard
    		while (!kbhit()) {
    			// load led array
    			tmpDataPtr = dataPtr;
    			tmpCharOffset = charOffset;
    			tmpCurrentChar = currentChar;
    			for (i = 0; i <= 22; i++) {
    				ledArray[i] = *tmpDataPtr++;
    	 			if (++tmpCharOffset==0x06) {
    	  				tmpCharOffset = 0;
    					if (++tmpCurrentChar == messageLength)
    	 					tmpCurrentChar = 0;
    	  				tmpDataPtr = &led_chars[message[tmpCurrentChar] - 0x20][0];
    			if (++charOffset == 0x06) {
    				charOffset = 0;
    				if (++currentChar == messageLength)
    					currentChar = 0;
    			dataPtr = &led_chars[message[currentChar] - 0x20][charOffset];
    			// display led array
    			row = 0x02;
    			for (j = 0;j <= SCROLL_DELAY; j++) {
    					LED_DATA = (ledArray[i] & row) ? 1 : 0;
    					LED_CLOCK = 1;
    					LED_CLOCK = 0;
    				PORTA = row;
 				row <<= 1;      // next line to be switched on
 				if (!row) 	// if last line go back to the first line
 					row = 0x02;
 	  			delay_us(800);
 	    			PORTA = 0x00;
		lcd_clear();
// return 1 if a key is pressed (non blocking)
// else return 0
int kbhit(void) {
	if (buffcnt) {
		// reset buffer variables (flush the buffer)
		inpt = kb_buffer;
		outpt = kb_buffer;
		buffcnt = 0;
		bitcount = 11;
		return 1;
    return 0;
// puts scan code (in hex format) into keyboard buffer
// (used for debugging purposes)
void put_scancode_kbbuff(unsigned char sc) {
	unsigned char h,l;
	// convert hi and low nibbles of the scancode
	// into ascii and store them into keyboard buffer
	h =  ((sc & 0xf0 ) >> 0x04) & 0x0f;
	if ( h > 9)
		h = h + 7;
	h = h + 0x30;
	put_char_kbbuff(h);
	l = sc & 0x0f;
	if ( l > 9)
		l = l + 7;
	l = l + 0x30;
	put_char_kbbuff(l);
// keyboard ISR
interrupt [EXT_INT0] keyboard_isr(void) {
	static unsigned char data;	// holds the received scan code
	// function entered at falling edge of the kbd clock signal
	// if data bit is the next bit to be read
	// (bit 3 to 10 is data, start, stop & parity bis are ignored
	if((bitcount < 11) && (bitcount > 2)) {
		data = (data >> 1);
		if (KBD_DATA)			// if next bit is 1
			data = data | 0x80;	// store a '1'
		else
			data = data & 0x7f; // else store a '0'
	if(--bitcount == 0) {		// all bits received ?
		   	decode(data);       // decode received byte
			bitcount = 11;		// reset bit counter
// decode scan code
void decode(unsigned char sc) {
 	static unsigned char is_up=0, shift = 0, mode = 0;
	unsigned char i;
	if (!is_up) {
		switch (sc) {
			case 0xF0 :// The up-key identifier
				is_up = 1;
				break;
			case 0x12 :// Left SHIFT
				shift = 1;
				break;
			case 0x59 :// Right SHIFT
				shift = 1;
				break;
			case 0x05 :// F1
				if(mode == 0)
					mode = 1;// Enter scan code mode
				if(mode == 2)
					mode = 3;// Leave scan code mode
				break;
			default:
				if(mode == 0 || mode == 3) {// If ASCII mode
					if(!shift) {// If shift not pressed, do a table look-up
						for(i = 0; unshifted[i][0]!=sc && unshifted[i][0]; i++);
							if (unshifted[i][0] == sc) {
								put_char_kbbuff(unshifted[i][1]);
					else {// If shift pressed
						for(i = 0; shifted[i][0]!=sc && shifted[i][0]; i++);
							if (shifted[i][0] == sc) {
								put_char_kbbuff(shifted[i][1]);
				else put_scancode_kbbuff(sc);	// scan code mode (debugging mode)
				break;
	else {
		is_up = 0;// Two 0xF0 in a row not allowed
		switch (sc) {
				shift = 0;
				break;
				shift = 0;
				break;
			case 0x05 :// F1 --  F1 puts you in debugging mode
				   // pressing F1 again gets you out of debugging mode
				   // in debugging mode hex code of the scan codes
				   // are stored in the buffer instead of their ascii codes
				if(mode == 1)
				mode = 2;
				if(mode == 3)
					mode = 0;
				break;
// store character in the keyboard ring buffer
void put_char_kbbuff(unsigned char c) {
	if (buffcnt < BUFF_SIZE) { // if buffer is not full
		*(inpt++) = c;
		buffcnt++;
		if (inpt >= kb_buffer + BUFF_SIZE) // pointer wrapping
			inpt = kb_buffer;
// get next available character from the keyboard ring buffer
// (waits until a character is available in the buffer)
int getchar(void) {
	int byte;
	while (buffcnt == 0); // wait for data
	byte = *outpt; // get byte
	outpt++;
	if (outpt >= kb_buffer + BUFF_SIZE) // pointer wrapping
		outpt = kb_buffer;
	buffcnt--; // decrement buffer count
	return byte;
void lcd_init(void) {
	delay_ms(50);
	LCD_E = 0;
	LCD_RS = COMMAND_MODE;
	LCD_RW = WRITE_MODE;
	delay_ms(1);
	LCD_DATA_PORT = 0x38;	// 8 bit, 2 lines, 5x8 font
	LCD_E = 1;	delay_ms(1);
	LCD_E = 0;	delay_ms(1);
	LCD_DATA_PORT = 0x0f;	// display & cursor ON, blink & underlined
	LCD_E = 0;	delay_ms(2);
	lcd_clear();
void lcd_clear(void) {
    LCD_DATA_PORT = 0x01;	// clear display
// display char on lcd
void lcd_putc(unsigned char ch) {
	LCD_RS = DATA_MODE;
	LCD_DATA_PORT = ch;
	LCD_E = 1;	delay_us(40);
	LCD_E = 0;	delay_us(40);
// display string on lcd
// input: pointer to string stored in flash ROM
void lcd_putsf(unsigned char flash *str) {
	while (*str!= '\0') {
    	lcd_putc(*(str++));
//  same as above except the string is in RAM
void lcd_puts(unsigned char *str) {
    	lcd_putc(*(str++));
howto design with pic moving message display
Are you also using MAX7219?
    V
software moving message
whats max7219 ?
ok here is everything in the zip file:
Protel schematic (also in .doc and .jpg format for those who dont have Protel)
C source code ,
i also included the Sillicon chip article from the first post
(i used the same article to build my LED display),
application note from Atmel explaining how to interface to AT keyboard
(i used bits of the code from the note in my source code)
, three pictures of the working display (already posted few posts earlier)
as I mentioned before the source is compiled with CodeVision compiler,
which also includes programmer software for STK 200 compatible
programers (and few others) , i only used their delay() library function
so the source is easily portable to any other compiler.
possible improvements could be:
-support for more than one message
(for example 6 x 50 char long messages)
-making menu system where user could select to save message(s)
in the onboard EEPROM, change saved messages, delete messages etc.
-detection if the keyboard is plugged in/out (maybe using onchip
analog comparator) this could be used to for example automatically
power LCD up and go into configuration mode , and when the keyboard is
disconnected LCD powers down, device goes into normal scroll mode
and displays currently selected message
-controlling the scroll speed via keyboard, currently its hard coded
into the source code via #define directive
-making the whole thing wireless, i.e. communication between LED display
and the main CPU board, (and eventually using smaller keyboard :))
so if any of you dudes have any suggestions for improvements or
if you do any or need help with building this display please let me know :))
Reactions: dector
    dector
hardware on scrolling message display
no problem, if you need any help with it let me know here,
i`ll be checking the forum regularly, the compiler I used
is CodeVisionAVR , trial version can be downloaded from:
https://www.hpinfotech.ro/
attiny2313 based moving message display
ok I had a look at max7219 , it`s a driver for 8x8
LED matrix, I am not using it in my display but I guess
I could, it would simplify the code as I wouldnt have
to do the complicated multiplexing through software,
and the hardware would probably be much simpler i.e.
no need for all the driver transistors , I`ll have a closer
look at the chip and maybe actually use it , thanks
for the suggestion :))
p.s. but i prefer doing ias much as possible in software,
so i dont have to use specialised hardware, its probably cheaper too
74164 diy
wow, 40 downloads in less than 24 hrs since I uploaded
the zip file :)) I didnt expect so much interest :))
I d like to hear your opinions and sugesstions, cmon dudes wake up,
i`m talking to myself here :)
led font generator free software
hi
here is the classic interface for rojo design now you can display large meesage as well
    Sadaf
