paradajz
Newbie
- Joined
- Jan 13, 2015
- Messages
- 2
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,297
Hello. I am using salvaged HDD motor (motor only, no PCB or anything else) and I wanted to feed its inputs to LM339 comparator. Motor generates two phase-shifted sine waves (+-500mV max), and purpose of comparator is then to convert those signals into digital ones (0/5V) so that I can use motor as rotary encoder. However, datasheet for LM339 says I can feed -0.3V into inputs, and I can generate -500mV, so that's an issue. Obvious solution is to use voltage divider on input, but am I going to lose some resolution from disk then? Any suggestions what to do?
