Divider in Megafunction Tools
fanwel
Full Member level 3
Hi all;
I want to write vhdl code for (A+B)/2 algorithm and will implement it in FPGA.
My input is an integer and this algorithm operates continuously with the next stage. For example:
1stage: (3+2)/2=2.5, (3+1)/2=2
2stage: (2.5+2)/2=2.25
The operation requires an integer number and also floating number. My question is which Megafunction tools are better to used: lpm_divider or altfp_div?
Need advise,thank you.
TrickyDicky
Advanced Member level 5
if it is just a divide by 2, or any 2^n, then the lpm divider is not neccessary, as you simply just to a right shift by n. You do not need floating point, the results will be fixed point.
fanwel
Full Member level 3
Hi TrickyDicky,
It is mean that I only need a shifter to make the division part? And how to make sure my code is synthesis? Thanks for reply
TrickyDicky
yes it is only a shift. In VHDL you can write the following code, and it should implement a shift register.
op <= ip /2.
Even better, have a look at the fixed point packages that make the bit numbers more easy to understand.
eg:
signal ip : sfixed(7 downto 0);
signal op : sfixed(6 downto -1);
op <= ip; (/2 implicit in the data type)
---------- Post added at 11:10 ---------- Previous post was at 11:09 ----------
This shows that in most circumstances, divide by 2^n is actually free (its just connecting wires together).
Reactions: fanwel
    fanwel
fanwel
Full Member level 3
Hi TrickyDicky,
I get your point. I will try it and will let you know if I get a problems.
Thanks for reply.
fanwel
Full Member level 3
Hi TrickyDicky,
For the addition operation, can I write the code using '+' symbol or I need to use lpm_add_sub?
TrickyDicky
you can use + for signed, unsigned and integer types.
fanwel
Full Member level 3
Hi TrickyDicky,
That means I can't use '+' for fixed point. Did you have idea on how to do the addition process?
I have write the division part using fixed point packages. Thank for reply
TrickyDicky
sorry, + is fine for fixed point too. You can use any of the functions in the package.
fanwel
Full Member level 3
Hi TrickyDicky,
Thanks for your helps..
fanwel
Full Member level 3
Hi TrickyDicky,
I have write the vhdl code for the addition and division ((A+B)/2) algorithm using fixed point package and the output range is (7 downto -1). Now, in the same stage I write for the subtractor (A-B) algorithm and the output range is (8 downto 0). My problems is I want the output come out one by one (single output). How to declare the output range for the main code since both of the output algorithms are not in the same range?
TrickyDicky
you will have to make sure they both have the same output bits. In this case, you probably want (8 downto -1). The a+b/2 will have bit 8 always set to '0', and a-b will always have bit -1 set to '0'.
fanwel
Full Member level 3
Hi TrickyDicky,
Sorry, what do you mean "The a+b/2 will have bit 8 always set to '0', and a-b will always have bit -1 set to '0'"?
Thank for reply
TrickyDicky
you would do it like this:
signal a,b,c,d : ufixed(7 downto 0);
signal temp1 : ufixed(8 downto 0);
signal temp2 : ufixed(8 downto 0);
signal op1, op2 : ufixed(8 downto -1);
temp1 <= a + b;
op1 <= '0' & temp1; --does a divide by 2 implicitly by type declaration
temp2 <= a - b; -- - always increases bit size
op2 <= temp2 & '0';
So now op1 and op2 are correct and have the same array size.
fanwel
Full Member level 3
HI TrickyDicky,
Is it the code is synthesis and can be implement in FPGA?
Thanks for reply
fanwel
Full Member level 3
HI TrickyDicky,
---------- Post added at 13:16 ---------- Previous post was at 13:09 ----------
Sorry again, how to know the code is synthesis and can be implemented? Can you suggest any document to learn more on this?
Thank you
fanwel
Full Member level 3
Hi TrickyDicky,
Thank you very much!
