Divider for synthesis
Edward_2288
Member level 4
dw divider
hi,
I encounter a problem in synthesising a divider to a gate level. for simulation, it can be simply done by using "/" symbol. however during synthesis, an error occurs.
well, anybody know how to synthesis division, let say by 3, 5, 7, etc, please advise me.
thx
niuniu
Member level 5
serial divider verilog
DC can not synthesize divider, you have to write your own implemenations. find some 'computer arithmatic' book on this topic.
Edward_2288
Member level 4
combinatorial integer divider verilog
anyone has the e-book or paper? actually, how many ways are they to build a divider?
kctang
Member level 1
divider verilog code with remainder
What are your requirements(speed, area, latency)?
Pure combinational, or digit-serial divider?
Edward_2288
Member level 4
divider with quotient and remainder
hi can u show me both ways? thx
kctang
Member level 1
The following combinatorial divider code is written by me when I was a undergraduate and it should be synthesisble. In fact the concept for digit-serial divider is the same excepted that "temp_remainder" is evaluated in each clock cycle.
Another higher radix division requires a lookup table first and you can find the theory in most computer arithematics books, enjoy!!
module divider(quotient, remainder, dividend, divider);
output [15:0] quotient, remainder;
input [15:0] dividend, divider;
reg [15:0] quotient, remainder;
reg [31:0] scaled_divider, temp_remainder, temp_result;
integer i;
always @(dividend or divider) begin
scaled_divider = {1'b0, divider, 15'h0000};
temp_remainder = {16'h0000, dividend};
for(i = 0;i < 16; i = i + 1) begin
temp_result = temp_remainder - scaled_divider;
if(temp_result[31 - i]) begin // Negative result, Quotient set to '0'
quotient[15 - i] = 1'b0;
end
else begin // Positive result, Quotient set to '1'
quotient[15 - i] = 1'b1;
temp_remainder = temp_result;
end
scaled_divider = scaled_divider >> 1;
end
remainder = temp_remainder[15:0];
end
endmodule
jimjim2k
Advanced Member level 3
Hi
for a collection of HDL codes for
Adder/multiplier/dividers and more look at:
check each of them with HDL lint tools for synthesizabiliy too.
1. h**p://ntu.csie.org/~b88047/p1/
2. h**p://ntu.csie.org/~b88047/p2/
* -> t
tnx
Edward_2288
Member level 4
any link for verilog?
btw, what is the difference between pure combinational and digit-serial divider? is it the number of cycles required to complete a division? thx
seasonyangd
Member level 3
China
Here is a paper on this topic?
It is a SNUG paper about divider implementation using verilog.
Edward_2288
Member level 4
integer i;
end
end
end
end
endmodule
Hi...this code will be synthesized into what? how many counters? how many adders? substractors? thx
kctang
Member level 1
This is a 16bit by 16bit, unsigned combinatinoal divider with no counters. It should have 16 subtractors of various width(max 32).
Edward_2288
Member level 4
so it means that in one clk cycle, we get the result of division. am i rite?
xwcwc1234
Full Member level 5
Any one knows where can get a synthesizable Verilog code for digital filter ?
kctang
Member level 1
Yeap, it gets the result in a single cycle. But it is slow due to cascaded subtractors.
taotaocui
Newbie level 6
Maybe you can use DW divider in DC during ASIC implementation or Coregen or MegaFunction in FPGA.
It's no a good method that you write everything you need yourself.
heartfree
Edward_2288 said:
what is DW divider?
DW -----Design Ware
this is a kind of IP provied by Synopsys.
If you are licensed, you can make a reference when RTL coding.
kinjal_book
Junior Member level 3
i have got quotient and remainder but i need to combine them to get the floating number
is there any good algorithm
posedge
Newbie level 1
Two years after original Topic was discusssed ?
It will be more effective for you if you open your own new topic on the subject:
"Synthesizable RTL Floating Point Dividers"
