Register Log in
[SOLVED] Distinguish feedforward path and feedback path
minhchau
Newbie level 5
Vietnam
Hello,
I am learning nested Miller Compensation to design LDO.
This image show the block diagram for a three-stage op amp with nested Miller compensation.
I have a few question:
Are Cm1 and Cm2 in feedforward path or feedback path? why?
And can you help me differentiate between feedforward path and feedback path
Thanks,
Chau
Dominik Przyborowski
Advanced Member level 3
Norway
It is not good example to learn how to distinguish both of them.
Each capacitor is connected in negative feedback, but provides feed forward as well.
The reason for this is value of impedance seen from both cap ends, which is comparable.
If last OTA would be an opamp (low output impedance) than you would see feedback path only.
minhchau
Newbie level 5
Vietnam
Thanks you, Dominik!
Do you have any specific documents or examples about this distinction?
If I use nested Miller Compensation to design LDO the system will have about 3 negative feedback loops,
when I evaluate the system's stability (by stb simulation in cadence) do i need to consider phase margin
and gain margin in 2 lnegative feedback loop, Cm1 and Cm2.
or I just evaluate the outer loop from Vout back to Vin.
Thanks you,
Chau
Norway
Stability is evaluated for the most outer loop (error signal flowing into OPAMP is interesting).
There is a lot of threads discussing stability on this forum.
    minhchau
Toggle Sidebar
