Distance to source for impinging waves planar
Circuit_seller
Full Member level 5
Planar Wave
Hi
What shuould be distance(in landa) of a source to an receiver antenna, to become impinging waves planar?
Re: Planar Wave
hello,
isn't this the same as the far field condition used in e.g. antenna measurements?
best regards
Re: Planar Wave
for far field condition:
L ≈ 2D²/λ
L is the measure distance , D is the antenna dimension
λ is the wavelength .
Re: Planar Wave
Hi
Length of antenna(monopole) is 1 meter and wavelength is 2 meter, so according to your formula L is less than 1 meter.
I think it is wrong.:D
Re: Planar Wave
this depends on the size of receiver.
Re: Planar Wave
Hi
What do you mean by size of receiver?
Re: Planar Wave
the formula could be found in electromagnetic book ,
I think it mentions that if L is large enough , and it could be
identified a far field.
L >> 2D²/λ
Re: Planar Wave
Well, you can not achieve a real plane wave. But you can create an approximation to it. What you need is an electromagnetic wave whoose amplitude and phase does not vary over a certain area. So the distance required to obtain such an approximation does depend on the size of the antenna or the aperture of the antenna.
Re: Planar Wave
Thanks irfan1
Suppose i have a 1m monopole antenna on top of a car, transmitter frequency is 140MHz and the eviroment is reflection free, what should be the distance from transmitter to receiver?
thnks in advance.
