nvinod_13
Newbie level 2
icl7107 + themprature + lm35
hi
i've got to do a mini project titled "instrumentation amplifier and display device"
so i've decided on a block diagram which has
1)temperature sensor
2)instrumentation amplifier
3)a/d converter
4)seven segment display
i've decided to use a temperature sensor maybe kty10 or lm 35.
what do i actually place on it to measure the temperature?
i've designed an instrumentation amplifier.now i need to convert it to digital and display.but i dont know how to interface all these.even if i were to display somethin then it wud be a voltage value.how do i bring about a relation between the temperature sensed and the voltage reading.
also i dont understand a thing about using an led driver before connecting to on led display.i believe icl7107 does a/d conversion and has in built led drivers but there is a diagram in the data sheet which says that there needs to be a latch and a seven segment encoder before icl7101 is connected to the led display.
please help with any suggestions.
hi
3)a/d converter
