Display algorithm in pc-based D.S.Oscilloscope
vahidkh6222
Full Member level 2
ds oscilloscope
Hi everybody
I am in doubt. i dont know if there is any well-known,well-documented methods in rebuilding waveform from stored window of sampled data in external RAM?
I mean, is it as simple as I think?! Is it enough that we Just transfer each sampled data byte and place a dot at the end-point of waveform?!! Don’t we need Any interpolation or additional manipulations for periodic signals?
help me if u can plz. i am gonna sank in my deep doubt....
ds-2100ac oscilloscope
nobody answers?!! pleeaasee! i promise you, you will go to heaven if u help me :) i have some good friends there.... huh:D
oscilloscope measure algorithm
You can do:
1. If you have enough samples, then you must abandon some of them. If you have let say 2000 samples, and you have monitor that can display 1024 horizontal dots then you have to display only 1024 of them. In this situtuation you'll have to use only part of samples.
2. But if you have 100 samples and you want to display them on 1024 horizontal dots then you can connect samples with straigh line or you can smooth lines with interpolation, ro some similar technique.
