Hello guys,
I wonder if anyone has used "MPRUN DISPATCHER" option in eldo 16.4. I have used it in older version (14.1) but when I tried to use the same script in 16.4 it gives an error as
".MPRUN: This command can not be declared inside a .alter section"
As I said, with the same netlist same simulation file (basically everything is the same), it works when I simulate it in 14.1 but not in 16.4.
I thought Mentor might change some syntaxes or something, so I wonder if anyone has faced this issue and I would appreciate it if you could tell me how you did resolve it!
I also wanted to ask a general question, what are the possible options for speeding up the simulation in eldo? I know about multi-threading, multi-processing, and premier. Is there any other option that it can make a simulation faster? I know premier has lots of options and I have tried some of them but I didn't see any improvement!
Thank you.
