Directional Loop Coupler
markito86
Newbie level 6
Newbie level 6
I am searching, paper, books etc etc to design, in HFSS or CST, Directional Loop Couplers, like this **broken link removed** (pag 35).
I don't undestand how the 2 SMA and the waveguide coupled and if the second SMA is load.
Then, in detail, where is the network between the 2 SMA and in which way.
Thanks of all...
The coupler looks like this
In the catalog photo, one port is terminated with 50 ohms, the other with a N connector.
Tks, this picture is perfect to understand the design, but have u also the dimensions of the structure (i.e. a, b, d, l1 ) ?
I copied the figure from a textbook, unfortunately it has no calculations, neither MIT volume 8, 10 or 11 has it as far as I see.
Basically the loop is interfaced to a standard rectangular waveguide, the loop length is usually < λ/4, the diameter of the round hole and loop distance to waveguide surface determines the coupling coefficients. According to literature, the loop may be rotated by a small angle (e.g. 15 degree).
