direct pic16f84 communication with com1 w/o using any IC.
mabauti
Member level 4
does someone have a subroutine?
thanks in advance.
budhy
Advanced Member level 3
Indonesia
Re: direct pic16f84 communication with com1 w/o using any IC
What do you mean with com1? Is it com1 of PC? If so, it can't be done, as the PC's COM1 is running on RS232 voltage level (<-5 Volt as logical "1" and >+5 Volt as logical "0"), it will burn your PIC out!
mabauti
Member level 4
I found this with google, however I didn't find the code =\
<img>http://images.elektroda.net/0_1167796149.gif</img>
Cortex
Full Member level 3
Morocco
you can use transistors instead of the max232!
regards
alzomor
Advanced Member level 2
Cairo
Hi
You can build your level shifter circuit instead of using max323.
but in order to do so you must have a reach power supply with + 12 and -12 and 5 volt . I think the +- 12 can vary .
The other solution is to use single 5 volt supply and make oltage dubler circuit .
which is not easy
Salam
Hossam Alzomor
mabauti
Member level 4
Re:
Well, I had to use a MAX232 after all :( (though the idea about 2 T's is not bad at all)
thank you anyway guys ;)
