[SOLVED] Direct Digital Synthesizer
ali ghafoor
Member level 4
Member level 4
how to measure the Locking Time for DDS practically?..i want to measure the Lock Time of AD9912
use a mixer as a phase detector (u need on with a DC coupled IF output). Line length L2 is much longer than L1, so it forms a delay line frequency discriminator. You might need to trim L2 or L1 slightly to get the mixer into quadrature. Drive the power splitter with >14 dBm. The oscilloscope shows the voltage out of the mixer, which stops changing when the DDS reaches final frequency and phase.
Reactions: kh4n
    kh4n
Syncronized zero span SA can be used to measure locking time any kind of PLL.External Sweep Triggering is coupled to Latch Enable signal-for instance- when sweep is triggered zero spanned ( Time Domain Mode) SA will show you ringing and locking time of the carrier.
