diodes mcq question
p11
Banned
Structurally, what are the two main categories of semiconductor diodes?
Vacuum and point contact
Electrolytic and point contact
Junction and point contact
Electrolytic and junction
What is a common use for point contact diodes?
As a constant current source
As a constant voltage source
As an RF detector
As a high voltage rectifier
Which component conducts electricity from a negative emitter to a positive collector when its base voltage is made positive?
A varactor
A triode vacuum tube
An NPN transistor
A PNP transistor
Why do many MOSFET devices have built-in gate protective Zener diodes?
The gate-protective Zener diode keeps the gate voltage within specifications to prevent the device from overheating
The gate-protective Zener diode protects the substrate from excessive voltages
The gate-protective Zener diode prevents the gate insulation from being punctured by small static charges or excessive voltages
The gate-protective Zener diode provides a voltage reference to provide the correct amount of reverse-bias gate voltage
Electron conduction in an n-channel depletion type MOSFET is associated with:
n-channel depletion
p-channel depletion
p-channel enhancement
q-channel enhancement
Electron conduction in an n-channel enhancement MOSFET is associated with:
q-channel depletion
p-channel depletion
Hole conduction in a p-channel depletion type MOSFET is associated with:
p-channel depletion
q-channel depletion
n-channel depletion
Hole conduction in a p-channel enhancement type MOSFET is associated with:
n-channel depletion
Point-contact diodes? Really? I can't remember the last
time - or any time - I saw anyone selling such a thing.
Cat's whisker and galena chunk, that's point contact.
Today you have plain junction (PN) for signal, switching
and power; PIN for RF tuning and switching; Schottky for
power and digital signal switching. The old "point contact"
diodes were Schottky type. But nobody calls them that
and nobody uses the truly point-contact structure, which
was always flaky.
Google or a text book can easily answer the simple school questions.
An old germanium diode (AM radio detector) is point contact and Google says 1N34.
EDIT: What is mcq? Why do some people talk in 3 letters?
