glias
Full Member level 2
Hello,
I'm looking for the value of the ideality factor of a temperature sensor mounted in a IR detector. I have contacted the manufacturer of the detector which only tells me which process he used : Fairchild, 2n2222A, process 1985. I can't contact technical from Fairchild (I'm already registered from their website, but it doesn't seem to work when I try to go in technical support, it comes back to the login page). If someone could help me or tell me how to contact Fairchild field application engineer...
Regards
Regards
