Diode for very high frequencies
dpa2007
Junior Member level 3
hi All,
i'm interesting for diodes that are working at very high frequencies (over 50GHz)
any suggestion is welcome.
I suggest you to have a look at PDB (Planar dopped Barrier) diode. We use it for the power measurement of RF signal at 50 GHZ.
See Application Note of Agilent.
Plannar Gun Diode over 100GHz.
https://eprints.gla.ac.uk/3984/
https://iopscience.iop.org/1674-1056/19/12/127203
Novel planar Gunn diode operating in fundamental mode up to 158 GHz
https://iopscience.iop.org/1742-6596/193/1/012029
thanks for your replies,
i will follow your suggestions,
At above 50 GHz, most diodes are marketed in chip form. If you need a really good Schottky diode , please contact Spacek Labs. Inc. "www.spaceklabs.com" for the diodes in "picopill" enclosures, 0.5 mm dia. x 0.4 mm long, usable up to >110 GHz.
thank you very much for your answers.
Step recovery diodes are also an option for the >10GHz application.
