diode cut in voltage
p11
Banned
plz some one explain me that why we see 0.7 volt fixed across diode even if we increase the voltage across it . i mean , 0.7 volt is the barrier potential.so it should decrease with increase in forward voltage , but we see 0.7 volt fixed no matter how much we increase the forward voltage . why ?
did you use a series resistor with the diode?
Or a current limiter?
Klaus
yes i have connected series resistance .......
The diode forward voltage is not constant, it varies logarithmically with current. It's just that at typical operating currents the voltage is around 0.7V.
Here's a example of the voltage versus current of a diode. Plot 2 shows the log relationship.
Reactions: p11
    p11
