L.A.W.
Newbie level 6
Hello everyone,
I am currently using a device that is designed to measure temperature from a diode connected BJT. The current data illustrates a 0.5 C difference between an NPN or a PNP transistor that is connected as a diode.
For the NPN case, the base-collector is shorted and a series of small currents are forced into this base-collector node (ranging from 10uA to 180u) and the \[\Delta\]Vbe is calculated. The PNP case is very similar. The base-collector is shorted together; however, current is forced through the emitter.
Attached is a photo of the connections.
There should be no difference in temperature measurements with all things being equal; i.e., same constant currents, same biasing at DP/DN (see photo), same length of PCB traces.
Is there something that I am not considering with NPN and PNP that may make a difference?
