Ding Dong Bell Circuit
atifkamal
Karachi, Pakistan
Friends,
I tried to make this small circuit, unfortunately i am not getting the result what this circuit is supposed to give.
i am just getting a single tone (not enough loud) when Pbutton contact is released what i think is "dong" sound but it is not like "dong"
i made this circuit on bread board for testing.
regards,
Genovator
Advanced Member level 2
India
What type of speaker are you using???? Try with an electret.
Have you designed the circuit correctly??? Check if the diodes are in reverse.
Genovator
India
I am not sure but you can change the transistor to TIP122 or any equivalent darlington pair. See if it works. I hope you will get only a 'ding' sound, but more clearer this time.
atifkamal
Karachi, Pakistan
hmm, i have directly attached spk to pin 3 and got a bit louder sound (i think tr is not working ok), it is not matter of sound amplification but it is supposed to produce both "ding" and dong". I have sucessfully tested another cirucit with two ne555 it is working as desired but that is also not "clean" ding-dong.
any suggestions, i am unable to find any ding-dong chip/cob (eg. 8021-2) here, so i have to go with these...
anyway i also need a cct. that produce "ding-ding-ding....."
Genovator
India
atifkamal
Karachi, Pakistan
sorry, i mean to say connected after resistor and was working with relatively low voltage. will check with darlington pair no issue.
Thanks i have made that circuit as you stated in your first link. Let me check if i can find HT 2811 in market.
Can you provide link to your simulation software???
Genovator
India
