Dimensions of the L-shaped slot
kwokhinglai
Member level 1
Dear All,
As shown as the attached L-shaped slot antenna (microstrip type), does anyone know any calculation or method to decide the dimensions of the L-shaped slot ?
Thanks a lot !
Thomas
it is depend on antenna form that you use. it is lamda /4 or lamda/2. you can use optimizing to easy simulation
1). The "lamda/4 or lamda/2" is used for the slot width or slot length ?
2). Also, should the position of slot be considered ?
Thanks a lot !
Thomas
hi you!
lamda/4 or lamda /2 is length of slot. lamda/4 if it is PIFA form....
it put at edge of Patch
Hi t25,
No need to consider the width of slot ?
Just design the width randomly in simulation software and then get the wanted result by "trail-and-error" ?
hi
i need lik this design simulated on hfss pleas help me
Added after 2 minutes:
pleas help me
i need a PIFA l shaped , dual band , simulated on hfss .
thanx
t25 said:
hi you!
