RF is just a medium. You need to have a modem at both ends. Generally modems have serial ports to connect to hosts(in your case, microcontroller). So once connected, you will basically be communicating transparently over the serial port.
RF is a range ...radio frequency...usually taken as 30-300MHz...usually suited for wireless communication case...
i dont think ur microcontroller will work fine at such high rates...
if you take rf to be a general sense...that is a medium...then just connect the two controllers together with a serial port
You need both transmitter and reciever in both sides. Many RF transcievers avilable.
you can use bluetooth module but you will meet a problems in interfacing USB with microcontrollers. The another solution is using XBee modules which is the latest technology . I used this modules from MAXSTREAM http://www.maxstream.net/
it is very easy to interface and very low power consumption
hi all
I want to build digital link STL (studio transmitter link) for only audio(fm radio station)
and for TV station(video and audio adn) and for only data
How can I build? ,where may I started?
is there any samle project or schema and what is rules digital link
you can use bluetooth module but you will meet a problems in interfacing USB with microcontrollers. The another solution is using XBee modules which is the latest technology . I used this modules from MAXSTREAM h**p://www.maxstream.net/
You can buy a Bluetooth module that has a serial port interface for your microcontroller and then buy the USB model for your PC. The just program both as if there were a serial cable connecting them. www.a7eng.com
hi all
