Digital to analog converter
laiza
Asia
what does "DAC 40/1024" means?
milind.a.kulkarni
Advanced Member level 3
Bangalore
In my view DAC stands for digitial to anlog convertor and 40 might be no of pins of the IC and 1024 stands for resolution of DAC i.e. 10 bit (2^10 =1024)
Good Luck
sinnadyr
Member level 2
40 pin DAC? I know DAC's are usually for small voltages (0-5V), but maybe this DAC manages up to 40V DC?
bigdogguru
Administrator
Southwest, USA
Where or what documentation did you read the phrase "DAC 40/1024?"
What is part number of the component to which the phrase refers?
As both milind.a.kulkarni and rhaynes mentioned 1024 most likely refers to a Digital to Analog Converter with 10 bits of resolution, 40 could represent the maximum sample rate in either kilo or mega samples/sec, KSPS or MSPS.
Specifying the document or URL which you found the phrase, "DAC 40/1024" would provide a more definitive answer.
BigDog
