SparkyBoy
Newbie level 5
- Joined
- Nov 23, 2010
- Messages
- 9
- Helped
- 2
- Reputation
- 4
- Reaction score
- 2
- Trophy points
- 1,283
- Location
- UK
- Activity points
- 1,360
I want to simulate a Ni1000 temperature sensor, effectively a variable resistor that changes by approx. 5.5Ohms/°C. This is easily achieved using a manual precision turn potentiometer of suitable range, but I would like a digital method as pots are bulky and tend to take up a lot of space and wiring etc.
I know digital pots exist, 1kOhm with 256 taps, approx. 3.9Ohms per tap, but to achieve a usuable temperature resolution I need finer control per tap.
A device measuring the resistance pulses 1.5-2mA through the resistance, measuring the volt drop and calculating the temperature using the Ni1000 characteristic curve.
So the question is can I take a dig. pot IC with say dual or quad pots per IC and connect them in parallel, just like resistors in parallel, to achieve a lower effective resistance?
Regards
Mark.
Regards
Mark.
