Digital Potentiometer
engineer123
Junior Member level 3
Hi All ,
can any one please If its possible post any assembly code for controlling Digital Potentiometer (MCP4011) from pic18f family , or to explain how can i program it ,
i have seen the MCP4011 Datasheet , but i'm not sure how can i generate U/D and cs signals from the pic.
thanks ,
abidr
Full Member level 5
33 N, 73 E
If you are using the pot for audio application than you d better off in using something like PGA231x, CS3310.
engineer123
Hi abidr,
No, i'm not using the pot for audio application. i need to do simple thing , just to know how can i move the resistor up and down thats all i need. i will make this more clear i need to click on the pc (up) the rsistor value changes (increases) click (down) the rsistor value decreases .
thanks
laktronics
Banned
You can control the potentiometer as follows:
Connect the CS pin to a port pin and U/D pin to another port pin.
To Move Up the pot:
1. Make CS bit high
2. Make U/D bit high.
3. Make CS Low
4. Make U/D Low, NOP, U/D High ; the pot moves up by one step.
5 . Repeat Step 4 as many times, as possible to move/ as you want the pot to move up.
6. Make CS high and lock up the position
Now to Move Down the pot,
1. MAke CS bit high
2. Make U/D low
3. Make CS Low
4. Make U/D High, NOP, U/D Low ; the pot moves Down by one step.
5 . Repeat Step 4 as many times, as possible to move/ as you want the pot to move Down.
Note:The pot position is volatile and need to be set everytime on power on.
Regards,
Laktronics
