Digital Filter using microcontroller
learner71
Member level 2
I want to design digital filters like low pass,high pass and band pass filter using microcontrollers. Kindly tell me, how can i do this on 8051.
Learner
klystron
South Africa
You need to be more specific on your filter requirements. Providing that the -3dB spec of your filter is low, the 8051 may nor be fast enough.
It will be an huge benifit if the micro processor can do A2D and D2A
horace1
Advanced Member level 5
Norwich, UK
depending on requirements I would use a dsPIC or a Txeas DSP processor. For a start have a look at
learner71
Member level 2
Thanks to all of you.
I do not know programming of DSP Processor. I want to make low pass filter using microcontroller. Can you tell me the logic, how should i make low pass filter.
Learner
horace1
Norwich, UK
permute
Advanced Member level 3
I would read up on filter design. The most basic lowpass filter might be something like:
y[n] = x[n] + x[n-1]
this would be the most basic moving average filter. the filtering capabilities are very poor, but it is very simple. The moving average is conceptually easy to understand, and a good starting point -- especially if it actually meets your requirement.
This type of filter also has a micro-friendly implementation based on recursion. eg:
y[n] = y[n-1] - x[n-2] + x[n]
The advantage becomes more apparent when you use a longer "window", eg:
y[n] = y[n-1] - x[n-32] + x[n]
This filter does require 32 samples of data be stored in memory, but requires no multiplications.
The most basic IIR filter is:
y[n] = k*y[n-1] + (1-k)*x[n]
which requires two multiplications, or requires "k" be chosen as a nice value. eg 0.5 or 0.25. (0.75 can be done using addition of 0.5 and 0.25)
