Digital Down Converter (DDC) or Zero-IF receiver
kurtulmehtap
Member level 3
Member level 3
Hi All,
I have a 70 Mhz IF, 2Mhz BW, QPSK modulated signal to demodulate.
Should I use a Digital Down Converter (DDC) to get the I-Q pair or should I use a downconverter to get Zero-IF as an input to ADC.
Which one is better?
Also for a 720 Mhz IF, 100Mhz BW, QPSK modulated signal which approach give better results?
Thank you.
720 MHz no way u will build so fast digital mixer on FPGA or DSP processor so that signal should be downconverted before going to your dsp block.
Remember that ADC itself can be used as downconverter, especially useful when u have narrow-band signal.
