hanif
Full Member level 4
I have to replace an analog display value of speed sensor with a digital one(7 seg display). the output of speed sensor is an analog sine wave signal (400 Hz freq). the amplitude of the signal is varied as the speed changes hence indicating the speed change as follows; max signal amplitude goes up to 13 Vpp.
2 Vpp --> 5m/s
3 Vpp --> 10 m/s
should i use an ADC directly + mcu based 7 seg display or there is some thing additionally needed because i need to change the display value according to the change in analog signal (because the ADC output continuously changes with the sine wave signal which is not required). I would be highly obliged if some body help me in this matter. waiting for reply
2 Vpp --> 5m/s
3 Vpp --> 10 m/s
