waqar86
Junior Member level 2
hello,
I am trying to develop a digital feedback control for a 45-W half-bridge converter, microcontroller used is from microchip dspic33fj16gs502. PWMs provided to the mosfets are around 3Mhz and the power to microcontroller is self-supplied through auxiliary output of transformer. Currently i only have feedback signals of auxiliary voltage and main_current that is passing through the half-bridge.
It has been observed that the relation Vout = A.Vaux + B.Imain holds with a slight error, so probably that can be used to get an idea of the current value of output voltage.
Now i have to develop a feedback mechanism such that the power supply maintains an output voltage of 20v and the PWMs should be set to have maximum efficiency, fo e.g if there is no-load at output , pwm should be in burst-mode.
Anybody having any ideas on how to implement this or anybody having worked on such a thing ??
Thanks in advance
Regards,
Waqar
Thanks in advance
Regards,
Waqar
