Register Log in
Digital communication over AWG18 cable
m_t_c
Newbie level 6
Hi all
There is a requirement to transfer 16-bit digitized signal (100-20KHz frequency range) over 500m long single wire (AWG18) with water acting as ground. What are the possible solutions for this?
Thanks & Regards
FvM
Super Moderator
Staff member
Bochum, Germany
Can use 44.1 ksps (CD standard) or 48 ksps. Reliable and EMC aware transmission of 800 kbps data stream requires a modem.
betwixt
Super Moderator
Staff member
Aberdyfi, West Wales, UK
Are you suggesting you use only one wire to carry the data and the return path is water? That might be more of a problem over 500m. It would depend on how conductive the water is, whether interfering signals are present and how the single wire is positioned relative to (or submerged in) the water.
Brian.
m_t_c
Newbie level 6
Brian.
Yes, but there is a possibility to use two wires (each 18 AWG) also., Moreover, solution is needed to be very compact. Are there any commercial ICs available for this purpose?
wwfeldman
Advanced Member level 2
18 AWG is about 21 mohm/meter
500 m is about 1 ohm
a pair is about 2 ohms. so the wire is not a significant voltage drop
use twisted pair to reduce external noise pick up
or better, twisted, shielded pair like belden 8760
if it will be exposed to the weather, you should use something with a more weather resistant outer jacket
Texas Instruments differential line driver SN75158 and differetial line receiver SN75157 are both available from digikey
they are designed for RS422, with a max length of 1500 m
betwixt
Super Moderator
Staff member
Using two wires I agree with wwfeldman, RS422 is best. There are many devices you can use, MAX488/489 and ADM488/489 for example. the '488 versions have one transmitter and one receiver in an 8-pin package.
I seriously wouldn't consider using water as one of the signal paths.
Brian.
m_t_c
Newbie level 6
Thanks for help. If data is being digitized using 16-bit ADC operating at around 100 ksamples/s, would RS422 be able to handle this data rate over 500m cable or i need to reduce sampling rate?
Thanks & Regards
--- Updated ---
Thanks for help. Currently i am using 16-bit ADC to digitize data at 100 ksamples/s. Will these ICs be able to communicate this data rate over 500m cable length?
Thanks & Regards
KlausST
Super Moderator
Staff member
Something is wrong here.
21mOhm/meter x 500meter = 10500mOhm = 10.5 Ohm
Incomplete information.
Mathematically this gives 1.6MBits/s. With UART includung Start abd Stop bits this means 2MBit/s
UART = NRZ, thus maximum (square wave) output frequency = 1MHz
But you need to add a frame sync signal to (at least) detect (at receiver side) which is High byte and which is Low byte.
..do you transmit a third byte?
Klaus
m_t_c
Newbie level 6
Hi Klaus
What more information i needed to mention plz?
I have not implemented any protocol yet. Currently, i am just searching the way to transfer ADC output over 500m cable (AWG 18 pair).
KlausST
Super Moderator
Staff member
If you want us to do some bandwidth calculations, we need to know how you want to transmit the data.
RS422 is no protocol, it just defines the electrical signals.
More important than the AWG is a true characteristic impedance of your signal pair.
Klaus
wwfeldman
my apologies for dropping the decimal point
m_t_c
Newbie level 6
The signal cable is Flexible 150 Strands 0.08mm of Tinned copper wire having impedance of 20m ohm/meter.
Currently i have interface ADC with a FPGA to store data as well as to generate control signals. Now, how to proceed further for data transfer over 500m cable was my initial query.
KlausST
Super Moderator
Staff member
This is somehow the opposite of what I was asking for.
Klaus
betwixt
Super Moderator
Staff member
I rather think that is the resistance, not the impedance.
Although resistance plays a part in the calculations, it is the impedance that decides how the data is to be transmitted. The impedance should remain constant regardless of the length.
Brian.
Toggle Sidebar
