DIGITAL CLOCK IN C ( NOT USING 'IF' Statements)
brucelee2
Member level 2
on a PCB
HI all,
Im trying to make a digital clock in using an 80515. I want to do it without using 'IF' conditions to check counters ect. I will then Display it on a 4X7segemnt display HDSP-B08G.
Apart from the Clock i also want to implement a BCD to 7-segment decoder without 'IF' statements.
I will need to use bitwise operators i assume but the technique im not sure of, any examples notes?.
OUTLINE:
TIMER -increment counter(needs to be reset with bitwise operators??)
Interrupt1 - To diaplay on the seven segments alternatly and fast enough for the human eye.
I WANT TO USE DIGITAL TECHNIQUES BUT WITH C :idea:
THANKS :D
I gather the use of bitwise operators for a task uses less 'processing power' from the Microcontroller. To become familier more familier with bitwise operators too.
Any ideas?
NEED TO BE REPLACED or different system with no IF statements. Does any body have an idea?
void Init_Timer(void)//timer zero
 TMOD=0x01;
 TR0=1;
 ET0=1;
 TH0=0xFC;  //64535 - 65535
 TL0=0x17;  //
void Init_int(void)
//turn off interupts the configure priority then turn on.
IEN0=0x00; //turn off interrupts.
           //3 interrupts-Timer1,-Button,-Display freq(most->least).
//NOT FINISHED YET
void ISR_timer(void) interrupt 1
 TH0=0xFC;    //xtal@12MHZ  ISR 12 machine cycles, timer reg incremented    every 1/1e6-->counter every ms
  TL0=0x17;
 counter++;
void main(void)
  Init_int();
  Init_Timer();
  port_init();
 while (1) {
             if(counter>=1000)  NEED TO BE REPLACED or different system with no IF statements
	 	    //printf("Time=%2:%2d:%2d\n", h1,m1,s1);
               s1++;
               counter=0;
             if(s1>59)
               s1=0;
               m1++;
             if(m1>59)
               m1=0;
               h1++;
               if (h1 >23)
	         h1=0;
THANKS!
Your code looks fine. I would probably write it in a similar fashion.
For a clock, which increments every second or every millisecond even. not much processing power is needed.
use ds1302
