Digital Audio Processing and Amplification
tooti
Newbie level 3
tda7439 code
Please help me I have to build a project, the topic is Digital Audio Processing and Amplification. The project should use a microcontroller and should perform basic functions as volume/bass/treble control and equalization. It involves an ADC and class D amplifier. please advise me on the microcontroller to use and the code (preferably in C/C++).
throwaway18
Advanced Member level 2
Kent, UK
tda7315 project
You will need a high end uC to do real time audio processing. Look for somthing intended for DSP.
sush
Member level 4
tda7439 audio microcontroller
no need to do all this. use "TDA7439" with 89c51(or any other simple microcontroller) and you can perform volume//bass/mid/treble/gain/attenuation control, simple and very cheap!
zkt
tda8551 project
Did you (or anyone else) finish the tda7439 project ?
sashijoseph
Junior Member level 1
Here's a project with TDA7315 and 68HC .........
    smurali60
zkt
The most difficult part is the pc board. Sparkfun has a smd to DIP daughter board that makes it easier. Havent got enought points to dl your file. What ir remote protocol did you use ? My goal was to use the Dishnetwork remote(RC5) which controls all my other A/V stuff.
Thats not too bad at all ! Using an Eeprom to store the settings is the way to do it. The 7439 has more inputs and is a better choice imho. So where`s the code.?
rajudp
India
you can use national lm4832 with any controller
