ehabzaky
Junior Member level 3
Dear All,
I' trying to implement a digitally controlled light dimmer.
I started from here
https://www.instructables.com/id/Arduino-controlled-light-dimmer-The-circuit/?ALLSTEPS
I construct the same circuit with TIC206D Triac.
I faced a problem for the 1K resistor feeding the Triac gate current it was burned once I started the circuit. I increased the (1/4) Watt to (1/2) Watt and even 1 Watt but all got burned too!
I started a trial testing for resistor values to replace it until I could run the circuit without having the resistor burned at a resistor value of 15 Ohms. In this case I found the gate current is 155mA so the resistor dissipated power is 0.432 Watt so I think using 1 Watt resistor will be OK. I already run the circuit like this for about an hour without a problem although I noticed the Triac and 15 ohm resistor are getting heated too much. But no burns of fires!
My first question is this setup is OK and this circuit can be used for long run and stable?
My second problem is that I can trigger the Triac and switch it on based on the signal from Arduino on the positive AC half cycle correctly but once turned on it continues on the remaining half cycle of the positive and the whole negative half cycle too and switch off only at the beginning of the new cycle. What I expect is the Triac should be turned off at every zero crossing of the AC sine wave i.e. twice per cycle once when changing from positive to negative and once when changing from negative to positive but it does on zero crossing on one direction only. At the end I can control the firing angle correctly for one half of the AC cycle only but the other half is totally passed to the load. I have checked the signal from my Arduino and it is perfect and being sent in both half cycles of the AC wave.
Appreciate if anybody could help me to solve this problem and get a stable working circuit.
Regards,
Ehab Zaky
I started from here
Regards,
Ehab Zaky
