youngguns21
Member level 2
I have a RF switch that I would like to select between two clocks (125MHz and 150MHz). The clocks are both LVPECL signals, 100ohm diff pairs. The SP2T inputs are 50ohm single ended.
Can I use a balun for the Diff to SE transform?
What kind of termination would I need on the diff pair side? 100 ohm resistor?
W
What is going to happen to the signal level at the 50 ohm side?
W
