aashishsharma
Member level 5
hey I am using max1415 adc in differential input mode. maximum Differential Input i am having is 4 volt p-p sine wave (ie 3- (-1)).
datasheet of max1415 tells me that max vref i can get (which is ref+ - ref-) is 1.75V. Now my que
1. since I can have -1V input at one pin does that mean i need to have atleast -1V at ref-? or i can simply get 0.875 and -0.875 volt at two pins ref+ and ref- respectively to get 1.75V. Ofcourse i can see that i would need to scale input down using registers to make in compatible with ADC input range which will be 1.75V. Also keeping in mind minimum voltage any pin in max1415 can take is -0.3V
2.common mode voltage for ADC input is 1V [(3-(-1))/2] does that effect common mode voltage for ref in anyway?
3. how to create differential refernce input? i just have 3.3V on board
i am really confused regarding this differential input and ref
Thnks in advance
datashhet :http://datasheets.maximintegrated.com/en/ds/MAX1415-MAX1416.pdf
Thnks in advance
