Hamid.Kiumarsi
Full Member level 2
Dear all
I have simulated an inductor in ADS's momentum.
For getting differential L and Q I can
1) either use one differential port
2) or use 2 single-ended ports and then get the mixed-mode S parameters.
Both above-mentioned methods of 1 and 2 for differential L and Q give same results.
However for getting single-ended L and Q I use single-mode S parameters.
There is a slight discrepancy in L and Q of the inductor if I simulate it with differential port or single-ended ports.
My question: is this common and normal?
