electrophysics
Member level 3
Hi. how to replace LM358 with LF353 (with jfet input) in switching power supply across current sense resistor as differential amplifier. I have tried the circuit with LM358. but it does not give good wave shape. on the other hand the problem with LF353 is that when I connect single ended supply it does not work. I think it requires dual power supply.
