Different timing constraints for timing paths in sequential circuits
Amir Yazdanbakhsh
Newbie level 5
Newbie level 5
I am trying to synthesize a sequential circuit. Suppose the design has two outputs (out1, out2). I want to define different timing constraints for each of the outputs. By this, I mean for example to put timing constraint 0.5 for all the paths that lead to out1 and timing constraint 0.75 for all the paths that lead to out2. Following you can see my Verilog design:
module test(clk, a, b, c, out1, out2);
	input	clk;
	input 	a, b, c;
	output	out1, out2;
	reg a_reg, b_reg, c_reg;
	reg out1_reg, out2_reg;
	wire out1_w, out2_w;
	assign out1 = out1_reg;
	assign out2 = out2_reg;
	assign out1_w = ((a_reg & b_reg) | c_reg);
	assign out2_w = ((a_reg | b_reg) & c_reg);
	always @(posedge clk)
	begin
		a_reg <= a;
		b_reg <= b;
		c_reg <= c;
		out1_reg <= out1_w;
		out2_reg <= out2_w;
	end
endmodule
