Differences between Hercules and Calibre
heartfree
hercules runsets fuer calibre
Backend team in our company use Calibre as signoff tool.
synpscrk
Junior Member level 1
hercules runsets
In general, Calibre is better than Hercules in performance, capacity and speed. But if your flow is dominated by Synopsys tool, you should use Hercules.
carrie
Member level 1
hercules vs. calibre
Calibre is preffered.
raymond_zhang
calibre vs hercules drc flow
thx all
any other signoff tools?
wadaye
Full Member level 4
Re: hercules vs. calibre
raymond_zhang said:
thx all
Assur@ from cadence.
pyrite
Member level 2
As far as I know, most of the foundry use Calibre as their sign off tools.
raymond_zhang
in general foundry release both Calibre and hercules runset .
BTW ,does sign off means DRC/LVS?
cikyen
Member level 3
I think both tools have their own pro and con. Some of the feature, calibre did a better job compare to hercules, and the other way round for some other feature. It's totally up to the user preference.
shelkerahul
Member level 4
Bangalore
HI
CALIBRE is the signoff tool and it is tsmc reccomended
Rahul
crazy_man
Member level 3
Calibre is preffered as it is the TSM signoff tool
xuxia
it is obvious trend that alll foundry and design house adapt the calibre as the standarize signoff tools.
stormwolf
Calibre is better, and more popule.
buzzybug
Newbie level 3
calibre is preferable for sign off tool
gliss
Advanced Member level 2
Yes, Calibre could be considered the standard.
tuza2000
Full Member level 2
calibre is the better tools , assura is another good tools.i am using both them now!
rakeshnunna
Member level 4
Calibre is the widely used sign-off tool. It is used in TSMC Reference flow as well.
hung_wai_ming@hotmail.com
Full Member level 6
For sign-off means foundries accept for tape out as foundries will run DRC/LVS for your GDSII as well, so you need to match the tools they use, that's why they release the rule sets for you.
For tools, there are most likely three tools
Calibr@ from me@tor graphics
Dracul@ from Cad@ence
Hercule@ from Syno@psys, which is A@vanti previously
Assura@ is seldom used by ppl as it's not efficient. It's just for running small blocks and small chips as it can integrate normally to Cadence@ layout tool and so you can simultaneously view ur errors online. Others most likely use command mode
luancao
Member level 4
But you'd better follow the fundary's suggestion...
beckchm
Banned
Calibre is standard .
The performance is better and it is preferred.
