Difference of AT89c51 & AT89S52
dayal
Member level 3
difference between at89s51 and at89s52
Hai,
can anyone tell me what is difference between AT89C51 and AT89S52, which is better we can use for industrial application..
Thanks & Regards
dayal
different between at89c51 and at89s52
I recomended 89S52, large memory...
regards
different between at89s51 and at89s52
89S52 is ISP programmable. You can use a simple parallel port programmer to flash it.
difference between at89c51 and at89c52
CMOS & pasicr are right ,me also recomended 89s52
diferences between at89s52 and at89s51
yeap.....ans is very easy..
the 89c51 is the prototype.while S52 is in system programmable.
feature C51 S52
ram 64bytes 128bytes
rom 4k 8k
timers 2 3
for more details check the attach ment of
cell phone controlled robotic rover.ppt in edaboard
that is my proj 's ppt it explains all the difference of c51 and 852
best luck
difference bitween at89c51 and at89s52
Some more
S52 is cheaper than c51(here in India)
Operating voltage also differ (please check datasheet)
nandhu
differences between at89s51 and at89c51
nandhu015 said:
Some more
nandhu
hi
Nice to know that,here s52 series is expensive in PAKISTAN(Islamabad),than the c51
Shakeel
difference at89s52 and at89c51
s52 is better than c51
S52 can be programmed with 3 wire only
(using AEC_ISP) that connectet with pararel port
