Difference between VHDL and Verilog
ajeetsingh
difference between vhdl and verilog
Hi all,
Please tell me difference between VHDL and VERILOG and using application area of both.
Thanks.
difference between verilog and vhdl
Difference between VHDL and Verilog please refer the attached file.
differences between vhdl and verilog
Personal point:
VHDL is easy to behavioral modeling
Verilog is suitable for RTL coding
difference between vhdl & verilog
ajeetsingh said:
Hi all,
Thanks.
you can search the paper written by Stephen Bailey-Technical Marketing Engineer
A very good introduction of VHDL/Verilog/SystemVerilog, especially their difference and pros and cons.
The title of this paper is "Comparison of VHDL, Verilog, and SystemVerilog"
Thomson
Good Luck
what is difference between vhdl and verilog
yeah, this paper is great....it always replaced the topics asking about these differences....
verilog is more close to transistor level modelling(low abstraction level)
while vhdl is more behavioural and abstract
Added after 5 minutes:
there is also...in the FPGA part of the forum
https://www.angelfire.com/in/rajesh52/verilogvhdl.html
chk that out....helpful also
differences between verilog and vhdl
nice, thank you !!
difference betweenvhdl & verilog
thanksssssssssss
Added after 22 seconds:
thanksssssssssss
Added after 13 seconds:
thanksssssssssss
1. Verilog is based on C, while VHDL is based on Pascal and Ada.
2. Unlike Verilog, VHDL is strongly typed.
3. Ulike VHDL, Verilog is case sensitive.
4. Verilog is easier to learn compared to VHDL.
5. Verilog has very simple data types, while VHDL allows users to create more complex data types.
6. Verilog lacks the library management, like that of VHDL.
Read more: Difference Between Verilog and VHDL | Difference Between | Verilog vs VHDL Difference Between Verilog and VHDL | Difference Between | Verilog vs VHDL
