A software interupt is drive by a predifined period of time usual a counter, that overflows or reaches zero, that triggers the interrupt routine, where as a hardware interrupt is from an external force for example a switch. HTH
as far as i konw those are still hardware interrupts....
the hardware interrupts could be internal (like timers) or external (like io change or communication receive) which are generated by specific hardware (the timer is also a internal harware periferal, separated from the internal CPU).
some microprocessors (and thus some microcontrollers) have an specific instruction for a "software interrupt" which 'generates' or 'emulates' the behavior from a hardware interrupt, but it's 'called' from the user program (via the software interrupt instruction (like an ASM nemonic of SWI in a 6800, or a software reset in others micros (which some people consider a interrupt per-se))
a software interrupt call is different from any normal call by:
-it calls to a specific interrupt vector like a hardware interrupt.
-if the micro is capable, it will also save the working area (like accumulators and some registers) like a hardware interrupt
-you end the interrupt routine like any interrupt (via a interrupt-return in contrast with a normal return)
-if the micro is capable of some configuration or it has only one interrupt vector, you can 'call' a hardware interrupt from the main code.
so, a software interrupt emulates most features from a hardware interrupt, even you can use some hardware interrupt routines via a software interrupt. but not many microcontrollers have an actual real software interrupt instruction.
