taofeng
If you do ac analysis in spectre simulator, and then print the DC operating point of the interesting transistor, you will see gds and ro. Normally I treat 1/gds as the output impedance of the transistor, is that correct ?
However, I still see that there is another paramater : ro, is it the same one ?
which one should be used for analog design or small signal analysis ?
