Noise would typically be additive to original signal. Distortion would probably represent a chance to an original signal. So in general, we expect noise would be uncorrelated to original signal, distortion error would be highly -correlated to the original signal.
in general.noise is an external source that change the normal shape of signal and distortion is the difference of normal shape and shape that u obtain .
Thanks replying, well what I am able to understand is that the noise is an unwanted signal that is added to your original signal and distortions is an unwanted signal that is added to your signal nonlinearly. Correct me if am wrong
