Microsoft offers a runtime version of Microsoft Access for download. This allows people to create Access solutions and distribute it for use by non-Microsoft Access owners (similar to the way DLLs or EXEs are distributed). Unlike the regular version of Access, the runtime version allows users to use the Access application but they cannot use its design surfaces.
---------- Post added at 11:42 ---------- Previous post was at 11:33 ----------
Microsoft Office Access, previously known as Microsoft Access, is a relational database management system from Microsoft that combines the relational Microsoft Jet Database Engine with a graphical user interface and software-development tools.
The number of simultaneous users that can be supported depends on the amount of data, the tasks being performed, level of use, and application design. Generally accepted limits are solutions with 1 GB or less of data (Access supports up to 2 GB) and performs quite well with 20 or fewer simultaneous connections (255 concurrent users are supported). This capability is often a good fit for department solutions. If using an Access database solution in a multi-user scenario, the application should be "split". This means that the tables are in one file called the back end (typically stored on a shared network folder) and the application components (forms, reports, queries, code, macros, linked tables) are in another file called the front end. The linked tables in the front end point to the back end file. Each user of the Access application would then receive his or her own copy of the front end file.
Access is more suited for desktop use with a small number of users accessing it simultaneously. One reason you might choose to use Access over SQL Server is for compatibility/sharing. You might need to email someone a copy of your database. People are more likely to have Access on their desktop computer than SQL Server. You'll generally only find SQL Server on developers' computers/servers or on production server machines.
Another reason you might use Access instead of SQL Server is money. You might already have installed Access as part of the Microsoft Office suite. Purchasing SQL Server would be an extra expense that may not be necessary - depending on your situation. SQL Server can also be quite expensive.
