Register Log in
difference between dpsk, psk
jess17
Junior Member level 3
can someone explain the difference between dpsk and psk please
Ahmed Alaa
Full Member level 5
Egypt
PSK is embedding info in the phase of transmitted signal. DPSK sends the phase differences between BPSK info symbols in order to allow for incoherent demodulation (the phase is not needed but only phase differences needed).
Mudasir Mir
Kashmir
Differential phase shift keying is a non coherent form of phase shift keying which avoids the need for a coherent reference signal at the receiver. Further PSK needs coherent detection due to its phase shift with a refrence signal. you should keep in mind that no coherent receivers are easy and cheap to build.
the reason behind non-coherent detection of DPSK is because its phase changes with its own delayed signal,nd we generally use this technnique.
with regards
Toggle Sidebar
