difference between default generic and default technology
siva_7517
Full Member level 2
Full Member level 2
hi all,
What is the difference between default generic and default technology in symbol library? Can I use two different technology library artisan and ambit :
default generic = ambit library
default technology = artisan library
Is it possible?
Re: difference between default generic and default technolog
Generic by default is when u start to synthesize a design, there are 3 steps,
optimize,
tech Mapping and
netlist generation.
So at At the 1st step it optimizes the design using a generic mapping, i mean the generic library inbuilt in the synthesis tool(sample) are mapped, and then later on the required tech mapping is done as according to the library provided
generic library has no drive strength, and all fliflops are same.
technology lib - tech dependent
generic lib - tech independent
