Difference between Bit rate and Baud rate
vinoth14
Junior Member level 1
What is the difference between Bit rate and Baud rate?
more commonly today Symbol Rate= Baud Rate is only same as bit rate using 1 bit per symbol.
Compression methods include N level amplitude and phase point to represent many bits into one symbol to maximize bandwidth compression in Bit's per Hertz.
Other variables are redundancy, FEC, tolerance to fading, modulation type, group delay, multi-channel etc.
